It is currently Tue Jun 09, 2026 8:06 am
 Post subject: T 5 gearbox
PostPosted: Sun Apr 29, 2012 2:02 am
first prototype . Next step, build the bevel gears for the differntial .
 Post subject: Re: T 5 gearbox
PostPosted: Sun May 06, 2012 7:49 pm
First test for the differential bevel gear .
PostPosted: Wed Jun 27, 2012 12:26 pm
hey good photo of the straight-cut gears
a great job on your T5 gearbox
may i ask in your photo
is this a polymer for the bevel-wheel?
PostPosted: Thu Jan 31, 2013 7:04 pm
Yes , this is a polymer . It is for testing the machine adjustment . After it is ok in polymer , I cut it in steel . All gears for the T5 are ready in steel .
PostPosted: Fri Feb 01, 2013 3:01 am
certainly a great effort to build this T5 gearbox.
she will be a sporty car to drive
looks a close ratio gearbox
a very interesting project
thanks for sharing it is an inspiration
to me the box seems lightly built almost flimsy
its lay shaft is a narrow diameter
PostPosted: Fri Feb 01, 2013 6:46 pm
I suspect that these small shafts are for test assembly purposes.I think the real ones will be thicker.....
PostPosted: Mon Feb 04, 2013 3:18 am
Right , this is a test assembly with a 25mm shaft . The real one has 42mm diameter .
PostPosted: Thu Feb 07, 2013 10:36 pm
this is the new shaft 42mm diameter hardened and ground . With the new gears made from steel and case hardened .
PostPosted: Fri Feb 08, 2013 2:23 am
Nice work on these gears! Do you know how the gears were hardened in the 1920's ?
PostPosted: Fri Feb 08, 2013 3:33 pm
Case hardening ,
PostPosted: Thu Sep 19, 2013 12:26 pm
How the gearbox looks today . The bronze bushings are still missing .
PostPosted: Thu Sep 19, 2013 1:10 pm
Super ! Gut arbeit.
Users browsing this forum: No registered users and 4 guests
